Stuck door will not open
WBATZ
  • 2005 HYUNDAI SANTA FE
  • 6 CYL
  • 90,000 MILES
The rear driver door outside handle broke - the child lock was on - now door wont open how can I get door open to fix it? Nothing broken that I can see but the door just wont open. The rear door on drivers side.
Do you
have the same problem?
Sunday, July 31st, 2011 AT 8:06 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
You will need to remove the door panel and work the child safety off so the door will open the door then fix the outer door handle.
Here is a guide that will give you an idea of how to remove the panel with diagrams below to show you on your car.
https://www.2carpros.com/articles/door-panel-removal
You might need to remove the rear seat to get the panel off and the panel may get damaged in the repair. Nothing you can do.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers, Ken
Tuesday, April 18th, 2017 AT 4:45 PM
DENNIS OWENS
  • 2001 HYUNDAI SANTA FE
  • 120,000 MILES
How can I get the hatch to release to repair it?
Thursday, January 7th, 2021 AT 6:48 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
We may have two possibilities that I can think of.
Something got stuck/jammed/wedged in the door or the mechanism. Sometimes it's the seat belt or a toy or other things!
or
There's a problem with the mechanism it'self.
My first approach would be to try the interior locking lever (on and off a few times) and do the same with the key from the outside. It might be that the internal rods have not moved far enough to let things loose or the rod for one or the other "unlock" has come loose. You may have tried this already (probably). This would be the easiest thing if it works!
The "wedged" possibility.
This will require two people, one to hold the handle "open" constantly (try the interior [with the window down] and exterior handles one at a time). The "handle person" needs to stay out of the way!
#2 person is going to lay on the seat, if possible. Depending on your situation something protective might be draped on the doors interior. Maybe a towel, blanket, or foam. #2 person will select a strong flat space on the door. With the handle open (#1 guy), #2 guy is going to deliver a good swift kick to the door (closest to the exterior handle end of the door).
After several attempts at this, abandon the suggestion. More kicking and screaming is going to probably tear something up bad!
Now we have the mechanism possibility, this will most likely be the hardest to get to. It's sometimes difficult to do this with the door open. You will have to take special care in getting in there. I've seen people even remove their seat to gain better access.
Here's one of our "Repair Guides" (from the top right of our pages) that may guide you along:
https://www.2carpros.com/articles/test-or-change-electric-power-door-locks
Around here are: "you go get it yourself" auto salvage yards!
Many of them don't care what you do out there, but an "excuse" might be that you are getting a window motor. Just to play it safe with your car, you might could find one like yours in the salvage yard and see exactly how the panel(s) come off. Sure, it's "time", but you are not spending any money!
Keep us posted with progress.
The Medic
