Camshaft position sensor?
JERRY29123
  • 2006 MERCEDES BENZ C230
  • 105,000 MILES
My wife has a 2006 mercedes c230 sport. It had two codes that were intermittent, they were po012 and po022 it was running fine with no misfires or anything noticable until she came to a stop at a light. It started running rough and almost wouldn't go. Codes now po304 305 and 306. I replaced the cam magnets and got rid of po012 & 022. What could cause all cylinders to missfire on one bank? I switched the cam sensor with the other bank and also the coils, I replaced the plugs, now I am at a loss. Could it be an oxygen sensor. If so up or down stream. Thank Jerry
Saturday, February 2nd, 2013 AT 2:02 AM
  • 52,797 POSTS
This is common when the boot from the intake to the supercharger goes out. I just had this problem with my car. Roy
Saturday, February 2nd, 2013 AT 6:19 PM
JOEMAC230K
  • 2005 MERCEDES BENZ C230
  • 1.8L
  • 4 CYL
  • MANUAL
  • 80,000 MILES
Code p0010, a camshaft position actuator circuit/open bank 1. Replaced camshaft position magnets. Code p0010 returned, idling rough. Replace camshaft position sensor(s) next? Where are they located? I have also replaced thermostat (p0128), spark plugs and air filter. Any help would be greatly appreciated. Thanks.
Monday, August 24th, 2020 AT 2:55 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,833 POSTS
I know what wrong with your car. My wife's car had the same problem. Check the boot between the intake manifold and the super charger in the back. Its tough to get to use a flash light. This is a thin boot that tears and causes that code even though it has nothing to do with what the code is. German ECM's are not real good about calling out the right system that is having a problem.
Please let us know what you find.
Cheers, Ken
JOEMAC230K
Thanks very much for your reply. I watched your video on maf sensor cleaning, replacement & I think it takes me out of my comfort zone. I'm trying to find an honest repair shop, avoiding the dealership like the plague. Your videos made thermostat, cam adjuster magnets, & spark plug replacement simple. At least I ruled out the cam adjuster magnets & did some necessary maintenance on my own. You armed me with enough knowledge to have an intelligent conversation with a repair shop. Thanks again!
KEN L
  • 42,833 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
JOHNSONSTEPHEN31029
Ken, please help me. I have the same issue with my 2005 C230 Kompressor. Can you give me more description of where that is. Or a picture? Please
KEN L
  • 42,833 POSTS
Here is a picture of the boot that goes bad. Check out the diagrams (below). Please let us know what happens.
JOHNSONSTEPHEN31029
Well, Mr Ken, bad news for me. Mine jumped timing. The teeth on the right adjuster are worn and or broken. The chain and the other adjuster looks good. Any special advice you can give, I'm in a bind on cash right now and I need this running to get to work and back? I really need to replace just that one adjuster and maybe come back in and do it all in a few months.
JOHNSONSTEPHEN31029
Wanted to add a better picture.
KEN L
  • 42,833 POSTS
Bummer, yep you are going to need to replace the actuator. Here are diagrams and instructions that will help you get the job done. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
2 CAR PROS
Hi Ken, I want to make sure I'm replacing the correct part. Can you confirm that the boot that needs to be replaced is part 70 "Intake Muffler Boot" (Mercedes part #A2710920596) in this diagram:
https://nemigaparts.com/cat_spares/epc/mercedes/1/m/271948/63a/07/040/?chasis=20324069P
I want to make sure I'm following your directions correctly.
KEN L
  • 42,833 POSTS
Yep that's the part alright you will need to use this hose clamp tool to do the repair.
https://youtu.be/S1q6HVe8Iw0
Let me know how it goes
SAMMHI23
  • 1.8L
  • 4 CYL
  • TURBO
  • 142,000 MILES
Where is the camshaft position sensor located on a 2005 Mercedes C230 kompressor?
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
Check the fig 1 and fig 2 camshaft position sensor location.
Let us know if you need more help.
MERCEDES-C230
  • 1997 MERCEDES BENZ C230
I have a 97' Mercedes c230, starts up fine but when I put it in Drive/Reverse, the car shakes a little and the idle changes. Last time I ran OBII on it(about 2 weeks ago), I got a camshaft sensor error. Any idea how to fix the problem?
ERNEST CLARK
  • 1,730 POSTS
If you have a code for that sensor, the computer is telling you there's something wrong with that circuit. So make sure to test the wires, connectors and sensor before assuming it's the sensor. Because too often techs replace a sensor because the computer says so, and they end up with the same problem anyway.
  • 52,797 POSTS
Good morning,
The light will reset itself and have 50 drive cycles with no issues.
Otherwise, you need a scan tool to clear the codes.
Tuesday, April 5th, 2022 AT 9:08 AM
