Camshaft timing problem?
TIMFE
  • 2011 FORD FIESTA
  • 1.4L
  • 4 CYL
  • TURBO
  • FWD
  • MANUAL
  • 90,000 MILES
Fitted timing belt using locking pins. In both cam and crank.
Car bad starting. When started slow revving and barking through inlet, like timing is out.
Tuesday, September 27th, 2016 AT 12:43 PM
  • 31,938 POSTS
You will have to re check valve timing do not assume that it is correct make sure, and do a leak down test to see if a valve is open, it may be a binding valve stem.
Tuesday, September 27th, 2016 AT 2:43 PM
FATI6610
  • 2007 FORD FIESTA
  • 2.0L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
I replaced front crank oil seal and need don't know crank pulley position to knock sensor for car listed above St150 model. Please show pictures.
Wednesday, October 7th, 2020 AT 11:56 AM (Merged)
Attached you will find the procedure for the crank pulley on a 2.0L. This should be what you need. Check out the diagrams (Below). Please let us know what happens. Thanks
MARIO0507
  • 2005 FORD FIESTA
  • 4 CYL
  • FWD
  • MANUAL
  • 12,000 MILES
Hi gents
i have a problem on my ford fiesta 1.6i ghia 2005, I change the timming belt but there are no timming belt marks on the pulley. I need some sort of a diagram, or advice on how to set the timming or how to turn the sharft please thanks
i thank you
mario hugo
DAVE H
  • 13,383 POSTS
We do not have adiagram for this vehicle i'm afraid !! your local library or autoparts store should be able to supply a manual for the vehicle with step by step instructions for the repair !
https://www.2carpros.com/forum/automotive_pictures/266999_aaa_4.png
DJA
  • 1999 FORD FIESTA
  • 137,000 MILES
I was wondering how often the belt has to be changed as I am thinking of buying a fiesta for my first car and want to make sure the belt is good before if I do buy it
PROMECHANIC
  • 536 POSTS
It depends on the engine but for most of the Fiesta engines it is either 100,000 or 150,000 miles.
I would change it or make sure it has been changed recently.
