2000 Cadillac Escalade interior door handle
JDPIPPO
  • 2000 CADILLAC ESCALADE
  • V8
  • AWD
  • 110,000 MILES
How do I repair/replace driver's side interior door handle?
Do you
have the same problem?
Sunday, July 6th, 2008 AT 4:09 PM
BTEXPRES1
Go to ebay motors and search for replacement part. Make sure that it is for the left side/LH or for the right side/RH. It is just a matter of removing the outer plastic trim around the door handle. It should pry off with a small screwdriver. A rivet holds the assembly in place. Drill out the rivet and slide the assembly forward or backwards. I can't remember which way.
Monday, January 26th, 2009 AT 11:02 AM
Recommended Guides
