2000 Cadillac Escalade brake light switch
GJJ25
  • 2000 CADILLAC ESCALADE
Electrical problem
2000 Cadillac Escalade V8 Four Wheel Drive Automatic
how to change a brake light switch on a 2000 esclade.
the switch is located above the brake pedal.
Do you
have the same problem?
Saturday, January 31st, 2009 AT 5:27 PM
BLUELIGHTNIN6
  • EXPERT
Twist it and it comes out. The stop light extension harness has a little metal bar on it. Push this down and the switch pops right off.
Thanks for using 2CarPros. Com!
Saturday, January 31st, 2009 AT 5:38 PM
GJJ25
The brake switch is locatd above the steering column and up and in behind the dash. The only way I that I saw in was through the dash.
I was asking if thre was an asier way. I could not find the stop light extension harness
i did look for it
Saturday, January 31st, 2009 AT 6:11 PM
BLUELIGHTNIN6
  • EXPERT
? Stoplight switch is mounted on top of brake pedal
Saturday, January 31st, 2009 AT 6:29 PM
GJJ25
Yes the brake light switch is located at the top of the pedal. Close to the inner part of the dash.
Saturday, January 31st, 2009 AT 7:20 PM
BLUELIGHTNIN6
  • EXPERT
Okay, all research I have found looks like you will need to remove the lower underside panel of column in order to gain access to switch.
Saturday, January 31st, 2009 AT 7:32 PM
GJJ25
So does this mean I dont have to take the entire dash apart.
Saturday, January 31st, 2009 AT 7:46 PM
BLUELIGHTNIN6
  • EXPERT
Not entire dash, no. Should just remove panel that is above brake pedal to gain access. Usually contains 4 - 6 bolts in panel.
Saturday, January 31st, 2009 AT 7:48 PM
GJJ25
Yes I did take that off. But I did not see a way in. But I will look again. Thanks a million man. I do owe you. This has been a lot of help.
Saturday, January 31st, 2009 AT 7:59 PM
Recommended Guides
