1999 Cadillac Deville Car taking is time to start
TWARE
  • 1999 CADILLAC DEVILLE
  • V8
  • AWD
  • 137,200 MILES
I had the battery checked on my car and it is fine. So I changed out the spark plugs and wires. But it still takes it's time to start, it will turn over but hesitate to start. I'm thinking it may be the alternator, but im not sure. What could it be besides the alternator?
Do you
have the same problem?
Wednesday, July 1st, 2009 AT 7:53 AM
FACTORYJACK
  • EXPERT
Does cranking speed seem normal? If it takes some crank time before it starts, it could have a fuel pump that is slow to build pressure, or a leaking fuel pressure regulator diaphragm. If you know where the regulator is, disconnect the vacuum hose and check for raw fuel. What happens is twofold, raw fuel leaks into the intake forced by rail pressure, and the pressure lost needs to rebuild during cranking.
Wednesday, July 1st, 2009 AT 10:36 PM
Recommended Guides
