1997 Cadillac Deville
BCINVENT
  • 1997 CADILLAC DEVILLE
Engine Mechanical problem
1997 Cadillac Deville V8
what is the crank torque specs of a 1997 4.6 northstar engine y engine code
Do you
have the same problem?
Saturday, October 31st, 2009 AT 5:52 PM
FACTORYJACK
  • EXPERT
Fastener Tightening Specifications
Application
Specification
Metric
English
Air Conditioning Compressor Bracket to Lower Crankcase Lock Nut
30 N m
22 lb ft
Air Conditioning Compressor Bracket to Lower Crankcase Stud
25 N m
18 lb ft
Air Conditioning Compressor to Block and Bracket
50 N m
37 lb ft
Air Conditioning Compressor Mounting Bracket to Compressor
25 N m
18 lb ft
Brace--Left Bank (Long)
75 N m
55 lb ft
Brace--Left Bank (Short)
50 N m
37 lb ft
Braces--Right Bank
50 N m
37 lb ft
Camshaft Bearing Cap
12 N m
106 lb in
Camshaft Chain Guide Access Plug
4.5 N m
39 lb in
Camshaft Cover
10 N m
89 lb in
Camshaft Drive Chain Guide Bolts
25 N m
18 lb ft
Camshaft Drive Chain Tensioner to Block
25 N m
18 lb ft
Camshaft Seal Retainer to Cam Cover (Left Hand Head)
3 N m
27 lb in
Camshaft Sprocket
120 N m
89 lb ft
Catalytic Converter to Exhaust Manifold Rear Pipe
50 N m
37 lb ft
Connecting Rod Bolt
First Pass
30 N m
22 lb ft
Second Pass
Back off to zero
Third Pass
25 N m
18 lb ft
Final Pass
+110 degrees
Coolant Temperature Sensor
20 N m
15 lb ft
Crankshaft Balancer Bolt
First Pass
50 N m
37 lb ft
Final Pass
+120 degrees
Crankshaft Position Sensor
10 N m
89 lb in
Cruise Control Bracket to Throttle Body Bracket
12 N m
106 lb in
Cylinder Block Coolant Heater - Right & Left
10 N m
89 lb in
Cylinder Head Bolt (M11)
First Pass
40 N m
30 lb ft
Second Pass
+70 degrees
Third Pass
+60 degrees
Final Pass
+60 degrees (190 degrees Total)
Cylinder Head Bolt (M6)
12 N m
106 lb in
Cylinder Head Plug
80 N m
59 lb ft
Cylinder Head Plug (Oil Gallery)
12 N m
106 lb in
Cylinder Head Plug (Soc Hex)
5.5 N m
49 lb in
Drive Belt Idler Pulley
50 N m
37 lb ft
Drive Belt Tensioner
50 N m
37 lb ft
EGR Pipe (to Intake Manifold)
25 N m
18 lb ft
EGR Tube (to Water Crossover)
25 N m
18 lb ft
EGR Tube to Intermediate Pipe Nut
60 N m
44 lb ft
EGR Valve
25 N m
18 lb ft
Engine Flywheel Bolt
First Pass
15 N m
11 lb ft
Final Pass
+50 degrees
Exhaust Manifold Pipe to Cylinder Head
25 N m
18 lb ft
Exhaust Manifold Pipe to EGR Tube
60 N m
44 lb ft
Exhaust Manifold Pipe to Exhaust Manifold Rear Pipe
25 N m
18 lb ft
Exhaust Manifold Pipe to Lower Crankcase
25 N m
18 lb ft
Exhaust Manifold Rear Pipe to Right Manifold
40 N m
30 lb ft
Exhaust Manifold to Cylinder Head Lock Nut
25 N m
18 lb ft
Exhaust Manifold to Cylinder Head Bolt
25 N m
18 lb ft
Flywheel Housing Cover Bolt
9 N m
80 lb in
Front Cover Bolt
10 N m
89 lb in
Generator and Air Conditioning Bracket to Block Bolt
50 N m
37 lb ft
Generator Bracket to Block (Rear Bolt)
47 N m
35 lb ft
Generator Bracket to Block (Rear Nut)
38 N m
28 lb ft
Generator to Bracket (Front Lower Bolt)
50 N m
37 lb ft
Generator to Bracket (Front Upper Bolt)
50 N m
37 lb ft
Generator to Bracket (Rear Bolt)
50 N m
37 lb ft
Ignition Module Bolt (to Cam Cover)
12 N m
106 lb in
Intake Manifold Bolt
10 N m
89 lb in
Intermediate Sprocket Retaining Bolt
60 N m
44 lb ft
Intermediate Sprocket Shaft Bolt
10 N m
89 lb in
Knock Sensor
20 N m
15 lb ft
Lift Bracket--Front
50 N m
37 lb ft
Lift Bracket--Right Rear
50 N m
37 lb ft
Lower Crankcase to Block (M8 x 1.25)
30 N m
22 lb ft
Lower Crankcase Bolt/Stud (In Sequence) (M10 x 1.5)
First Pass
20 N m
15 lb ft
Final Pass
+65 degrees
Oil Cooler lines to Oil Cooler
18 N m
13 lb ft
Oil Cooler Lines to Oil Filter Adapter
18 N m
13 lb ft
Oil Filter Adapter
16 N m
12 lb ft
Oil Filter Adapter Plug w/Oil Cooler
20 N m
15 lb ft
Oil Filter Adapter Plug w/o Oil Cooler
18 N m
13 lb ft
Oil Level Indicator Tube
10 N m
89 lb in
Oil Level Sensor
20 N m
15 lb ft
Oil Manifold Plate to Lower Crankcase
10 N m
89 lb in
Oil Pan Bolt
First Pass
8 N m
71 lb in
Final Pass
12 N m
106 lb in
Oil Pan Brace
50 N m
37 lb ft
Oil Pan Drain Plug
20 N m
15 lb ft
Oil Pump Suction Pipe (Lock Nut)
25 N m
18 lb ft
Oil Pump to Lower Crankcase
First Pass
10 N m
89 lb in
Final Pass
+35 degrees
Oxygen Sensor
40 N m
30 lb ft
Power Steering Pump (to Bracket)
25 N m
18 lb ft
Power Steering Pump Bracket (to Block)
50 N m
37 lb ft
Starter (to Block)
30 N m
22 lb ft
Starter Motor (Lock Nut)
10 N m
89 lb in
Thermostat Outlet to Water Pump Cover
10 N m
89 lb in
Torque Converter to Flywheel Bolt
47 N m
35 lb ft
Torque Strut Bracket to Cylinder Head
50 N m
37 lb ft
Torque Strut Bracket to Cylinder Head (Stud)
50 N m
37 lb ft
Torque Strut Bracket to Water Manifold
25 N m
18 lb ft
Transaxle Bel Housing to Engine
75 N m
55 lb ft
Water Crossover (to Block)
25 N m
18 lb ft
Water Crossover (to Head)
25 N m
18 lb ft
Water Crossover Plug
25 N m
18 lb ft
Water Outlet Fitting
50 N m
37 lb ft
Water Outlet to Cylinder Head
25 N m
18 lb ft
Water Pump Assembly
100 N m
74 lb ft
Water Pump Drive Belt Shield Retaining Bolt
10 N m
89 lb in
Water Pump Drive Belt Shield Retaining Nut
10 N m
89 lb in
Water Pump Drive Belt Tensioner to Water Crossover (Stud)
10 N m
89 lb in
Water Pump Cover to Water Pump Housing
10 N m
89 lb in
Wednesday, November 4th, 2009 AT 10:33 PM
