1996 Cadillac Deville How to do a pressure test?
Transmission problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic
Hi ~ A couple of weeks ago I had a question about our transmission, as we have suddenly lost all gears, but fluid is not burnt. I was told for diagnosis we should first do a transmission fluid line pressure test to see if the pump has output. We are now ready to do that, but need to know three things:
(1) What should the pressure be? (Ie - on the gauge)
(2) What gear do you test it in?
(3) Where do you find the place(s) to connect the pressure gauge to? How many testing ports are there?
Thanks again for your much needed help!
Do you
have the same problem?
Tuesday, June 30th, 2009 AT 9:19 PM
Below is the test procedure, the pressure port is a bit difficult to access. If you look at where the lower trans oil cooler line fitting is on the front, follow straight down 4-5 inches or so and you'll find the 1/8th inch pipe plug, that is the test port. Below I've also included a symptom chart for loss of drive and loss of reverse.
Line Pressure Check
Line pressures are calibrated for two sets of gear ranges-Drive-Park-Neutral, and Reverse. This allows the transmission line pressure to be appropriate for different pressure needs in different gear ranges:
Gear Range
Line Pressure Range
Drive, Park or Neutral
Minimum line 50-55 psi, Maximum line 230-250 psi
Minimum line 90 psi, Maximum line 300 psi
Before performing a line pressure check, verify that the pressure control solenoid for the transmission is receiving the correct electrical signal from the vehicle computer:
Hook up the scan tool.
Start the engine and set the parking brake.
Caution: Keep the brakes applied at all times in order to prevent unexpected vehicle motion. Personal injury may result if the vehicle moves unexpectedly.
Check for a P0748 malfunction code from the pressure control solenoid of the stored transmission. Check for other malfunction codes.
Repair the vehicle if necessary. Include the following areas:
" Inspect the fluid level
" Inspect the manual linkage at the transmission
" Install the line pressure gage.
Put the gear selector in Park and set the parking brake.
Start the engine and allow the engine to warm up at idle.
Enter the diagnostics routine and select MISC TESTS.
Increase the transmission fluid pressure by commanding low amperage. Read the corresponding line pressure on the pressure gage.
Compare your data to the Drive-Park-Neutral line pressure chart below. This line pressure is valid for PC solenoid overrides with the vehicle stopped at idle and in Park-Neutral.
If your pressure readings differ greatly from the line pressure chart, refer to Symptom Tables.
Loss of Drive
Channel Plates
Drive and Driven Sprockets
Drive Link Assembly
Driven Sprocket Support
Damaged, porosity, leaking
Final Drive
Damaged, splines worn
Final Drive Pinions
" Spalled pins or pinions
" Lack of lube
Forward/Coast Clutch Support
No lube
Forward Sprag Clutch
Worn, broken or locked
Manual Valve and Link
Not attached to detent lever
Pump Shaft
Scavenge Pipe Seal
Damaged or missing
Scavenger, Primary Pumps
Seized, broken pump gears
Torque Converter
" Broken lug, failed lug weld
" Sheared lug bolts
" Worn turbine shaft splines
" Low fluid
" Pump hub cracked or broken
" Internal failure
" Closure weld failure
" Cover cracked at weld
Turbine Shaft
Dislodged, stripped splines
No Reverse
Case Cover
Case Cover Gaskets
Damaged or displaced
Checkball in Piston
" Porosity or broken
" Feed holes blocked
Driven Sprocket Support Bolts
Loose, not in grooves, mislocated
Driven Sprocket Support Seals
Fluid Pressure
Too low
Lo/Reverse Anchor Pin
Anchor pin broken or not positioned
Reaction Carrier Shell
Missing, teeth damaged
Reverse Band
Broken, worn not anchored
Reverse Band Apply Pin
" Too short or binding in case
" Broken
Reverse Clutch Fiber Plates
Splines or friction material worn
Reverse Clutch Housing
Reverse Clutch Piston
Binding in case
Reverse Clutch Piston Seals
Leaking, damaged or worn
Reverse Clutch Spring Assembly
Reverse Clutch Steel Plates
Splines worn
Reverse Servo Piston
" Bad seal
" Damaged housing
Snap Ring
Tuesday, June 30th, 2009 AT 11:03 PM
Recommended Guides
