1993 Cadillac Deville Engine Timing
STEWART1
  • 1993 CADILLAC DEVILLE
  • V8
  • FWD
  • 82,000 MILES
I have recently done a head gasket replacement on a 4.9 v8. I have everything back together and running except I have not got the timing set correct. The chilton manual I have says to jump some pins A&B on the ALBL connector. I can not locate it, nothing looks like what is pictured in the manual. My? Is where is this ALBL connector located at?
Do you
have the same problem?
Tuesday, January 13th, 2009 AT 7:13 PM
BMRFIXIT
  • EXPERT
Check behind center of instrument panel ,below ashtray
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_155.jpg
Tuesday, January 13th, 2009 AT 7:32 PM
