Engine wont crank
KALISZHA
  • 1998 CADILLAC DEVILLE
  • V8
My secruity is on and my car wont crank on my 98 cadillac deville. I change the dash clutch so can u walk me through resetting the car?
Monday, May 2nd, 2011 AT 4:49 PM
WRENCHTECH
  • 20,757 POSTS
30 Minute Re-Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes ( the vehicle is now ready to relearn the Passlockâ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the Passlockâ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6. Start the engine (the vehicle has now learned the Passlockâ Sensor Data Code and/or password).
7. With a scan tool, clear any DTCs if desired (history DTCs will self clear after 100 ignition cycles).
If this doesn't work check this guide out
Monday, May 2nd, 2011 AT 6:24 PM
H8SPAMSOMUCH
  • 1997 CADILLAC DEVILLE
  • V8
  • FWD
  • 89,000 MILES
I am having a mid-life cadillac owner crisis, I have a 1997 Cadillac Deville every morning when o attempt to start the car it will turn over but it will not crank. After about two or three minutes of attempting to crank the car it will finally fire up and through out the day it will crank with no problems. I have had the battery replaced, I tested the spark plugs by removing the (spark plug) wires while the car is cranked and the engine becomes sluggish. That let me know that spark plugs are fine, also I have disconnected the negative post from the battery while the car was runni. Ng and it kept running with out anything happening letting my know that alternator is running fine. I have reset the OBD-II Trouble Codes in order to get some codes but none ever came back.
Friday, June 12th, 2020 AT 11:32 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sounds more like a fuel pressure problem. First, PLEASE dont remove the neg cable while the car is running anymore. The computers really dont like it, and your car has alot more computers than the average vehicle. If you remove the engine cover you will see a round vacuum pot mounted on the fuel rail, with a vacuum line to the intake up by the throttle body. Look for fuel in that vacuum line, if there is any at all, the fuel pressure regulator is blown and bleeding off all of the fuel pressure overnight. When you go to start it cold next time, turn key on but dont crank it over, then turn key off, then on, then off, then try to start it. This will build up fuel pressure and it should start fairly quick
FIDBLUE
  • 1999 CADILLAC DEVILLE
  • V8
  • FWD
  • 88,000 MILES
I got in my cadillac, turned key to start, would not engage
the starter. On the bottom of the speedometer it said
Starter disabled-REMOVE KEy. We have no cadillac dealer here. If you could help me, would appreciate it. Thanks,
fidblue
Friday, June 12th, 2020 AT 11:33 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sounds like an issue with the anti-theft system. If you have another key, try it before anything else. Sometimes also the metal shavings will build up in the tumbler, which affects the chip being read. You can try using computer cleaner (canned air) to spray into the tumbler to see if it will help it read. If not you may need to find a GM dealer (doesnt need to be Caddy) to do a diagnostic on the system
Did it work? Mine did the same thing today.
FELICIAGYTN
  • 1996 CADILLAC DEVILLE
  • V8
  • FWD
  • 127,245 MILES
My car would not crank, I just drove car ten minutes before with no problem, car was running car cut itself off and everything worked on car but now security light flashes but no lights on dash board radio does not come on and car doesnot crank, car has a north star engine.
  • 108,133 POSTS
Hi:
It sounds like there is a problem with the security system. The only problem is the only way to identify the problem is by taking it to a dealer where they have the proper test equipment.
BOOKERT
Engine Mechanical problem
1996 Cadillac Deville Engine Size unknown Wheel Drive Type unknown Automatic 150000 miles
when i`m trying to crank my car it just clicks
BUZZSAW
  • 1,198 POSTS
Either your battery is bad or it needs charged, or lose or corroded battery cables
BABIJESS2002
  • 11,000 MILES
When I turn key it acts like it wants to start but doesn't. Like It's choking for life.
Friday, June 12th, 2020 AT 11:34 AM (Merged)
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if okay-check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
KODYB1711
  • 1995 CADILLAC DEVILLE
  • V8
  • 110,000 MILES
I recently purchased this car, worked great first week. The remote did not have a battery but had all the keys. I set the alarm off first day I had it, placed the door key in driver door and it stopped, no further issues. Couple days ago, I set the alarm off again on accident, I did same thing with the key and door. This morning I go to start the car and nothing, does not start, turn the key in the ignition and nothing happens, does not turn over or click like it is trying to turn over, there is no dash lights on, radio does not turn on, no interior lights turn on, headlights do not turn on, no lights under the gear shift. I am clueless on what could be the issue. Alternator? Starter? Battery? Anti-theft system? Does anyone have any ideas?
HMAC300
  • 48,601 POSTS
Check fuses shown in picture one is under hood and other in trunk. Then make sure you have correct key or try another one if you have one not a new key.
KODYB1711
The first fuse says trunk compartment and looking at the fuses under the hood, I did not see a fifty amp Fuse or even one listed on the cover, do I have this mixed up?
HMAC300
  • 48,601 POSTS
Yes, one is in trunk and other is by battery it is a fifty amp fuse on left hand side under hood. The fifty amp may be a small fuse block.
FUBARDOSS
  • V8
  • FWD
  • 120,000 MILES
1995 Cadillac Deville Won't crank. Checked anti-theft, battery is good. When I turn the key to ON everything acts as normal, When I turn the key to start the car, it clicks once and then nothing and the display panel goes blank except for a couple idiot lights on top. Keep alive memory error and PCM memory reset are the only codes, probly because I've disconnected the battery multiple times for awhile
FACTORYJACK
  • 4,159 POSTS
Will it not take a jump start either? If it goes blank after crank, look for a poor connection. If you have been at the battery connections, and you have physically tightened them, then I would move further down the line. When you try and start, and it goes blank, tug on the positive cable at the starter, and also the ground cable near the starter to see if you regain power. Have you had the battery tested, specifically load?
FUBARDOSS
I took the battery to knechts and they put the battery on the super load machine thing(sorry not mechanical don't remember what it was called) and they tested it and it held fine. The car doesn't die the panel just goes blank and comes back when the key returns to on position. The remodeled did drop about 10 to 15 degrees between the last time the car started and hasn't been above freezing since, could this be part of the problem as well? The starter showed no signs before, started up 97% of the time before, usually would only not if I only flicked the key to start instead of hold it there
CADIEMAN
  • 3,544 POSTS
Sounds like a bad starter. Hold the key in crank possition and bang on starter to check goodluck
