Caliper change?
SCOTTIEBBC10169
  • 1994 CADILLAC DEVILLE
  • V8
  • 104,000 MILES
How in the heck do I take off the caliper to change brake pads? How to remove slip cover bolt or whatever it is? Thanks
Monday, February 22nd, 2010 AT 5:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to show you how to replace the front brake pads and a diagrams to help you see what it will be like on your car.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
Monday, February 22nd, 2010 AT 10:54 PM
WAKESK888
  • 21 POSTS
  • 1992 CADILLAC DEVILLE
  • V8
  • FWD
  • 138,000 MILES
I am trying to replace a couple wheel studs on my front right wheel an am not understanding how to get the calipers off so I can get to the studs. What is the easys way to replace the front wheel studs?
Tuesday, July 31st, 2018 AT 2:00 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Your calipers should have two torx bit bolts on the inside of the caliper. Once you get those off, then you will remove the rotor and get a press or c clamp and press the studs out of the plate.
WAKESK888
  • 21 POSTS
I am in the middle of trying to get the caliper off now. I do not have a Torque wrench so is there any other tool that I could use to get the torque bolts out with like an allen key or something. An if so what size are the bolts?
BUZZSAW
  • 1,198 POSTS
I am in the middle of trying to get the caliper off now. I do not have a Torque wrench so is there any other tool that I could use to get the torque bolts out with like an allen key or something. An if so what size are the bolts?[/Quote:d414fb1624]
its a 3/8th in hex nut or allen wrench, to get the studs out hit them with a hammer, to get them back in use two of you lug nuts to do it
WAKESK888
  • 21 POSTS
  • V8
  • FWD
  • 138,000 MILES
What kind of tool besides a torque wrench would I use to remove the two torque bolts from m front calipers so I can get to my replacing my wheel studs? Alos what side bolts are in there because I can't find anything to fit them?
Tuesday, July 31st, 2018 AT 2:01 PM (Merged)
BUZZSAW
  • 1,198 POSTS
Its a 3/8 in hex nut not a torx, and a wrachet
