Third brake light
LISAPIERCE
  • 2000 CADILLAC DEVILLE
  • V8
  • FWD
  • 110,000 MILES
How many fuses boxes on cadillac deville
Sunday, January 18th, 2009 AT 3:30 PM
2000 Cadillac Deville third brake light
Won't come On when brake is applied? Get back
Sunday, January 18th, 2009 AT 3:32 PM
LISAPIERCE
No, reverse light wont work and plate light wont work, and trunk interior light wont come on and trunk release wont release.
Sunday, January 18th, 2009 AT 3:38 PM
LISAPIERCE
No answer M. Rasmataz?
Sunday, January 18th, 2009 AT 3:56 PM
Sounds like you may have a bad fuse or possibly wiring issue. There is a fuse block under the rear seat int his car.
Read the guide below on using a test light, its the best way to test fuses
The wiring diagrams for your lights are attached below
Sunday, January 18th, 2009 AT 4:43 PM
ALDOG2100A
  • 1991 CADILLAC DEVILLE
  • V8
  • FWD
  • 98,000 MILES
My tail lights, brake lights and turn signals are all out. I checked all of my bulbs and fuses but they all seem to be ok. How would I go about troubleshooting this problem? Could this be a BCM problem or maybe just a short somewhere. Would a diagnostic code reader tell me where the problem might be? I need help because I can't drive this car anywhere without getting pulled over. Any help would be greatly appreciated
Monday, December 3rd, 2018 AT 5:46 PM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
You're going to need a test light to do some testing.
My first guess is a bad ground for the rear light harness.
2CP-ARCHIVES
  • 4,542 POSTS
  • 13,800 MILES
The third brake light wont come on when press the brake
DOCFIXIT
  • 18,828 POSTS
If rears work then suspect bulbs or wiring
GARYSTEVEN
  • 2002 CADILLAC DEVILLE
  • V8
  • FWD
  • 67,000 MILES
I lost brake lights today and have check all fuses within the car system i.E, under hood and under rear passenger seat. I check the relay switch and all was ok. No blown fuses, signals from all relays (Ohlms reading) still no lights. I was able to remove the tail lamp but unable to reach the bulb. Not sure how to remove the protective layers. Still no brake lights, all other lights in car work.I would appreciate any help possible.
Sorry, I can not donate at this time.
Gary
BLACKOP555
  • 10,371 POSTS
Check your brake on off switch, located on the pedal. Check and replace as needed.
GARYSTEVEN
Thank you for answering questions on 2002 DHS brake light system.
G
