Check engine light
CADILLAC G
  • 2010 CADILLAC CTS
  • 18,780 MILES
After inadvertently leaving the ignition switch in the accessory on position, and not realizing it, the battery died. After having it jumped, the car started up right away, no problem. Then I noticed the check engine light symbol on, how can I, myself, reset this light, being it's only on because of the battery going dead and then having the car jump started? Thanks!
Do you
have the same problem?
Thursday, September 12th, 2013 AT 8:48 AM
WRENCHTECH
  • 20,757 POSTS
You must have had a glitch in the system to cause the light here is a video that shows how to clear the codes.
https://youtu.be/ahK_eucFi-k
Thursday, September 12th, 2013 AT 9:17 AM
RICKYSH11
  • 71 POSTS
  • 2005 CADILLAC CTS
  • 6 CYL
I'm having a check engine light which is reading as a P0430 code Catalyst efficiency below threshold bank 2. I have a 2005 Cadillac CTS with about 126,000 miles. Does my catalytic converter need to be replaced or would it be an O2 sensor on bank 2 as specified in the check engine scan?
Monday, February 25th, 2019 AT 7:45 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
I need to know what size engine you have?
WRENCHTECH
  • 20,757 POSTS
That code is nearly always a bad converter. There are other possibilities but they are very rare. In order to set that code the front and rear 0/2s have to mirror each other for a specific period of time among other criteria it has to meet also.
RICKYSH11
  • 71 POSTS
Thanks, the engine is 3.6L. So, if I replace the catalytic converter should I replace the sensors also?
MWATTERSON
  • 40 POSTS
  • 2006 CADILLAC CTS
  • 148,000 MILES
I bought this car last year, from Texas. I drove it back home to
Utah. The Check engine light came on a couple of days after I got
It home. I had it checked at auto zone and the trouble shooting
Code is P0496. I was wondering if is the evap sensor, because
Gm said they would replace the evap sensor for free if it had less
Than 120000 miles. It also makes a emission smell that is sucked
Into the car when the heater is running and you can smell it from the
Drivers side motor under the wheel well. Could all this be related.
And could changing the evap sensor fix the check engine light and the
Smell thanks so much.
SATURNTECH9
  • 30,870 POSTS
Wrenchtech is right most of the ime it's a bad cat. Read step 3 I posted if everything checks out there then your next step is to replace the cat.I wouldn't replace the sensors they would both have to go bad at the same time to set that code. Let us know what you find and how it goes.
  • 31,938 POSTS
Possible causes
- Faulty EVAP Canister Vent Valve
- Faulty EVAP Canister Purge valve
- Plugged EVAP canister condition
- Faulty EVAP Pressure Sensor
- EVAP Canister Vent Valve harness is open or shorted
- EVAP Canister Vent Valve circuit poor electrical connection
Go get it changed for free.
WRENCHTECH
  • 20,757 POSTS
Even if both 0/2s were bad, I believe you would get different codes than a PO430.
RDEANJR
  • 2006 CADILLAC CTS
  • 62,300 MILES
Tech got 3 code off engine light.
1 loss communication with engine modeule. S00
2. High purge flow emission $00
3. Class 2 data link high ABS $28
what does it all mean?
HMAC300
  • 48,601 POSTS
Well you shold have sent the codes first not the diagnosis. It means that y ou culd have left your gas cap not tightened after getting gas, or your purge vavle may be messed up and needs to be fixed or a short in wire. The abs cold mean a wire broken someplacce andthe loss of communication can be abad battery/ground or a bad wire at the aldl or it wasn't hooked up reigh tto begin with.
MDWALL1965
  • 2007 CADILLAC CTS
  • 60,000 MILES
I've been told multiple locations, from under the hood, to inside the gas tank ( that one makes me scratch my head ! )
HMAC300
  • 48,601 POSTS
It's connected to the gastank on the right rearinner fender well. You can't see it unless you look under and then maybe not even then. It's connected to a rectangular box like thing.
MDWALL1965
Thank you So much for your reply, and pretty quick, too !
Found a mechanic who will repalce it for $150.00
The dealership wanted close to 300 !
Wanted to try it myself, but it's not my car, it's my girlfriends, and if I screwed it up, i'd NEVER hear the end of it, lol !
HMAC300
  • 48,601 POSTS
I hear ya
CHASINFLORIDA
  • 2003 CADILLAC CTS
  • 6 CYL
  • 115,000 MILES
Radio has been replaced but still only picks up AM, most of the time, FM normally doesn't work but comes and goes, changed o2 sensors and now they say problem is computer. 14.8 volts on display charging, then drops to 13.8, but with car off battery has only 11 volts.
Must drive everyday or batter won't start car. Battery has also been replaced.
Terrible service at cadillac so took to GM. No one has shown any knowledge of car.
Now sits in driveway and wife is bitching. Please Help!
ERNEST CLARK
  • 1,730 POSTS
Your O2 sensors are a separate issue from your radio and bat problem.
Your O2 sensors are controlled by the PCM, which is your power train computer. (Engine/trans) The radio and other electrical accessories are controlled by the BCM, which is your Body Control Module.
You said you replaced the O2 sensors, but are you getting another code? When the engine sets a code for these sensors, it IS NOT saying the sensors are bad. It's only pointing you in the direction of a problem. Such as the wiring/connectors/sensors. And also, your engine could be running a lean/rich condition that is causing the sensors to read something abnormally high/low, which your computer can't compensate for. Sometimes the computer will think there's a problem with the sensor or its circuit.
The proper thing to do when getting these codes is to thoroughly troubleshoot that particular system until the component at fault is found. If a mechanic just goes in to replace parts, you need to find another mechanic, one that knows what he/she is doing.
Your radio sounds as if the power antenna isn't connected properly or has a problem in the wiring. (FM stations need the antenna, AM stations don't) That's why the AM stations are coming in.
Your digital display should fluctuate from anywhere between 13-15 volts (While engine is running). That's normal. But when you engine is off, the bat should read 12.6 (at least)
If you've recently replaced the bat and it's already reading 11 volts, then there's a constant current draw on the bat that isn't shutting off when you turn the car off.
Check to make sure you turn everything off when leaving your vehicle. If the current draw doesn't disappear, then you'll need to have your fuse box probed for the current draw. And if you're unable to locate it this way, have your BCM checked out. These things often go bad and will cause all sorts of electrical gremlins to appear.
ANGELEYEZZZZ25
Hey I just recently got an 03 cadillac cts only had it for a little over a month. I get in my car one morning and it would not start it would just turn no crank up or anything radio worked but the car would not start. It's been three days and the cadillac dealership just told me the computer was bad so my car would not start. My warranty is over only had one month warranty with the place I got it from, but luckily with this problem it is covered by the factory warranty you should try that
DAN JOZ
  • 2003 CADILLAC CTS
How do you turn off the malfunction indicator lamp on a 2003 Cadillac cts
BLUELIGHTNIN6
  • 16,542 POSTS
If you are referring to check engine light then it requires a diagnostic scan tool to retrieve and then delete the codes out of system.
