2004 Cadillac CTS ignition
HAPPY2009
  • 2004 CADILLAC CTS
  • 6 CYL
  • FWD
  • MANUAL
  • 135,000 MILES
The ignition switch will not release the key when I go to turn the car off, what should I do
Do you
have the same problem?
Saturday, September 19th, 2009 AT 3:45 PM
ERNEST CLARK
  • EXPERT
Try putting a little pressur on your gear selector. Push it forwards (Towards park) and remove the key at the same time.
If this works, then you have a bent linkage/bad bushing in the gear selector mechanism.
If it doesn't work, then you possibly have something binding inside the ignition lock that is preventing it from turning completely to the "Off" position.
Sunday, February 28th, 2010 AT 11:41 PM
Recommended Guides
