1997 Cadillac Catera Air pump location
RICHC82357
  • 1997 CADILLAC CATERA
Suspension problem
1997 Cadillac Catera 6 cyl Two Wheel Drive Automatic 98.000 miles
Where is the air suspension air pump located on a 1997 Cadillac Catera? The "Leveling" light is flashing on the dash panel. Thanks
Do you
have the same problem?
Wednesday, July 22nd, 2009 AT 3:03 PM
FACTORYJACK
  • EXPERT
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
xTooltipElement
Service Information
1998 Cadillac Catera | Catera (VIN V) Service Manual | Suspension | Automatic Level Control | Diagnostic Information and Procedures | Document ID: 230293
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge.
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge, inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge.
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge.
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
" Replace the ALC compressor. Refer to Air Compressor Replacement.
" Replace the air tube. Refer to Air Tube Replacement.
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement.
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement.
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Wednesday, July 22nd, 2009 AT 10:18 PM
Recommended Guides
