How to install cabin air filter?
RINOPLA
  • 2001 MITSUBISHI MONTERO
I would like to know where is the cabin air filter located. Thanks
Wednesday, June 11th, 2008 AT 9:46 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,877 POSTS
Here is a guide to walk you through the steps and diagrams (below) that will show you how to replace the cabin air filter in a car.
https://www.2carpros.com/how_to/change_cabin_filter.htm
The images below are for your vehicle, looks to be behind the glove box
Tuesday, January 31st, 2017 AT 1:21 AM
ENONGENE LOUIS EJOLLE
  • 169,050 MILES
Does my car listed above have a cabin air filter and if so, where is it located? I just dismantled the glovebox and not sure how to reach it.
Tuesday, January 31st, 2017 AT 1:22 AM (Merged)
  • 31,938 POSTS
Looks as if your model does not use one, I had a look on Mitchel 1 data base and it shows a filter if used behind the glove box as shown in the picture below, but just to make sure please advise engine and trim level on your car, so I can do an exact search.
It is the 2001 Mitsubishi Montero Sports, V6 3.0, rear transmission, XLS model.
  • 31,938 POSTS
I put your car details in the data base and it came up with no result, so I would say that your vehicle is not fitted with a cabin filter.
CRISTIANLFLORES
  • 1999 MITSUBISHI MONTERO
  • 3.0L
  • V6
  • 4WD
  • 200,000 MILES
Does my vehicle have a cabin air filter? If so where is it located at?
WRENCHTECH
  • 20,757 POSTS
It does not have one.
CUTTER112
  • 2002 MITSUBISHI MONTERO
  • 6 CYL
  • 4WD
  • 160,000 MILES
2002 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 160000 miles
where is the filter for the cabin on my car. Do you sell the filter?
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2059.jpg
