1972 Skylark making a deep humming noise
WICKEDLYCOLD
  • 1972 BUICK SKYLARK
1972 Buick Skylark
51 thousand miles (i don't believe they are origional miles though)
i was driving down the road, and the car started throbbing like it was running out of gas, so I pulled over and popped the hood, and the hose going from the fuel filter to the cauberator was off, so I plugged it back up, and it drove fine. Then a little bit later, the car started making a whisteling noise, and a real deep humming noise was comming from below me, and it was vibrating the car when it did it
the car only did the humming noise and whisteling noise when I was giving it gas. I had a few people say it might be a vaccuum hose, or the driveshaft "u" joints. But the driveshaft isnt loose. I was wondering if anyone could help me out on what it is
thanks.
Do you
have the same problem?
Friday, December 29th, 2006 AT 7:40 PM
ABADAY
Check wheel bearings and pinion bearing
Monday, January 1st, 2007 AT 4:54 PM
Recommended Guides
