Cigarette lighter Fuse
LEONARD V. COFER
  • 2005 BUICK RENDEZVOUS
I would like to know which number fuse to replace for my cigarette lighter outlets?
Saturday, January 16th, 2010 AT 1:02 PM
  • 108,164 POSTS
Here is a guide to help check the fuse #32 and the fuse location diagrams (BELOW)
Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
Thursday, January 21st, 2010 AT 7:26 AM
DAVID THORNHILL
  • 2004 BUICK RENDEZVOUS
  • 6 CYL
The code scanner plug has no voltage, also the cigarette lighter don't work. If a fuse is bad, which one and where is it located.
Sunday, February 10th, 2019 AT 10:29 AM (Merged)
KHLOW2008
  • 41,815 POSTS
The cigarette lighter Fuse # 40 ( 20 A) in under hood fuse box. Here is a guide to help you test it.
MIKENM
My car is the six cylinder front wheel drive automatic with 115,000 miles.
Which fuse powers the cigarette light in the front console?
Sunday, February 10th, 2019 AT 10:30 AM (Merged)
IMPALASS
  • 3,112 POSTS
Here is the location for the cigarette fuse #32 and a guide to help you test it when you find it in the diagram below.
Cheers
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,877 POSTS
Hello
Thanks for the information, I show fuse #32, 20 amp, located under the hood right wheel housing.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_111.jpg
KEEKEE32
What is the fuse for the cigarette lighter for this one 2005 Buick Rendezvous CXL?
STEVE W.
  • 12,958 POSTS
For the front - Aux. Fuse 32 (20A).
For the rear outlet - Aux. Fuse 14 (10A).
TRACYLEA75
  • 3.4L
  • 6 CYL
  • AWD
  • 130,000 MILES
I have a 2004 buick rendezvous. I was changing the fuse for the cigarette lighter a couple of days ago, long story short, it isnt the fuse I need a new cigarette lighter. Can someone tell me how to go about doing that. Also, later the same day when I went to town I noticed my door ajar light was on. All the doors are shut. Played ring around the buick shutting them and nothing I cant figure it out. I locked it when I went in the store and the alarm kept going off. HELP! How do I fix this?
HMAC300
  • 48,601 POSTS
Try resetting your alarm system first, then for lighter they usually screw in hold back piece unscrew center piece if alarm still goes have it scanned may be a body module problem. Also make sure headlight switch doesn'thave interior light son. Body module may be light problem as well a pro will need to scan
MALINDADST
Where is the fuse for the lighter at?
Wednesday, April 24th, 2019 AT 4:26 PM (Merged)
DENNYP
  • 1,823 POSTS
There is a fuse panel located in the right side of the center console.(down near the floor) There is another one located in the engine compartment. Here is a guide to help you check the fuses with the fuse locations and diagrams below.
