Coolant temperature sensor location?
LEAKYSNEAKER
  • 2002 BUICK RENDEZVOUS
  • 6 CYL
  • AWD
  • 130,000 MILES
What is the location of the temp sensor? It's the coolant temp sensor/sending unit. I think it screws into the block somewhere. Thanks for your response.
Tuesday, November 30th, 2010 AT 3:48 PM
BMRFIXIT
  • 19,053 POSTS
Engine Coolant Temperature (ECT) Sensor lOCATED On top rear of engine, near thermostat housing. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, December 1st, 2010 AT 7:15 PM
ELTJAS
  • 6 CYL
  • FWD
  • 64,254 MILES
Hi I have heard good things about this website and I finilly I have to come and try to get help from you I need to find the sensor for the thermostat in my rendezvous and I dont know where is it can u help me please.
Friday, December 18th, 2020 AT 9:48 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Are you refering to the temp sensor that operates cooling fan. It is next to housing for thermostst
see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_58.jpg
THAOYANG
There is only one sensor that I know if you're referring to the coolant or thermostat sensor. I believe that the pic. Docfixit has posted is the only sensor, thermostat or Engine Coolant Temperature Sensor (ECT). It should be on the right side of the engine (being that you're standing in front of the car), it's located right underneath the throttle body and throttle cables.
