Driver side window stuck
NATEDOGG5693
  • BUICK REGAL
I have a '95 buick Regal 3.8L V6 with about 120000 mi. And recently the driver side window got stuck all the way down. It happened once before and when I took into the shop I had to pay like $150 to just get it put up, they wanted $400 to put in a new motor. Well, it happened again and I refuse to pay again without trying to fix it myself. When you press the switch you can hear the motor start and the window moves maybe 1cm. But then stops still well down in the door, What should I do?
Do you
have the same problem?
Thursday, April 12th, 2007 AT 12:03 AM
MERLIN2021
  • EXPERT
Replace the motor!
Tuesday, April 17th, 2007 AT 11:11 AM
Recommended Guides
