Electrical problem
1999 Buick Regal 6 cyl Two Wheel Drive Automatic
can you tell me how to replace the front turn signal light on a 1999 Buick Regal?
SPONSORED LINKS
Do you
have the same problem?
Friday, January 29th, 2010 AT 12:25 PM
EXPERT
If you can't get them from under the hood, there should be 2 steel slide pins. Pull them up and the light assembly should come out so you can access the bulb. Make sure when you replace the slide pins that they attach to the headlight assembly.
