1999 Buick Regal
MRROGERS
  • 1999 BUICK REGAL
  • V12
  • FWD
  • 12,000 MILES
Using a lot of antifreeze, but the car does not overheatand does not leak out. Antifreeze has to be replaced every two weeks.
Do you
have the same problem?
Saturday, January 17th, 2009 AT 5:52 PM
KEVIN12881
If you were putting in water it could evaperate, but if you are putting in anifreeze, then you are either leaking or burning. If you really only have 12K miles then you should be leaking (out of water pump, radiator, hoses, heater core-that would be inside the car and you would smell it) if you missed A 0 and have 120k, then you may be burning from worn pistons. Does your car smoke? What are the mile.12k?
Saturday, January 17th, 2009 AT 6:05 PM
Recommended Guides
