1995 Buick Regal Brake Lights not working wit h Turn signal
BOSAM3
  • 1995 BUICK REGAL
  • 6 CYL
  • FWD
  • 103,484 MILES
I have a 95 Buick Regal. When I turn on either turn signal, they work (as well as emerg flashers) ; the brake lights (both) go out. I noticed also that I have no brake lights unless I pull slightly back on the turn signal arm. I have replaced the brake pedal switch and still same problem. I have another 95 Regal, and the turn signal arm doesn't seem as 'loose' with play in it, as the one I'm having problems with. Could it be a ground wire prob. Or is it in the steering column with the switch - contacts?
Do you
have the same problem?
Friday, January 9th, 2009 AT 11:58 AM
DOCFIXIT
  • EXPERT
Turn signal switch in collum
Friday, January 9th, 2009 AT 3:36 PM
Recommended Guides
