1995 Buick Regal
PEACE1254
  • 1995 BUICK REGAL
Air Conditioning problem
1995 Buick Regal V8 Front Wheel Drive Automatic
Do I need to disconnect the air conditioner when repairing the radiater? One of the freeze plugs is near the airconditioner unit. Is there another way to release the freon from unit?
Do you
have the same problem?
Wednesday, March 17th, 2010 AT 8:55 PM
  • EXPERT
I'm not sure what you are working on. Is it the radiator or a freeze plug? If it's the radiator, you shouldn't have to worry about the AC. If it's a freeze plug and you need to remove the compressor, make sure there isn't enough room to just unbolt it and move it to the side. IF there isn't, the freon must be collected by a certified tech by law. You can't release it into the atmosphere.
Friday, March 19th, 2010 AT 11:42 AM
Recommended Guides
