1994 Buick Regal It wont start when the engine is hot.
AZSWEMT03
  • 1994 BUICK REGAL
  • 6 CYL
  • FWD
  • 189,000 MILES
Im having an issue with my 1994 buick regal. It wont start when it is hot. For example if I start it and go to the store. It wont restart after that. I have replaced the starter, battery and battery cables. When you go to restart it all you get is a click from the starter. If you try it a couple of times it will eventually start up. It runs fine after that. I also have had a tune up recently so I know its not that. This has been a issue getting worse over time. It was hooked up to the scanner for possible code issues but nothing came up.
Do you
have the same problem?
Friday, June 18th, 2010 AT 6:34 PM
Sounds like the ignition switch is failing
Friday, June 18th, 2010 AT 6:47 PM
Recommended Guides
