1993 Buick Regal turn signal
AWJSUN
  • 1993 BUICK REGAL
Electrical problem
1993 Buick Regal 6 cyl Two Wheel Drive Automatic
When I make a left turn and push turn signal arm down,
the turn signal does not start flashing. But if I tap up on the turn signal arm with my finger then it starts flashing and works fine.( I have to do this when I turn left, right turn works ok. What could be the cause and how would I fix it?
Do you
have the same problem?
Monday, September 8th, 2008 AT 10:39 PM
SERVICE WRITER
  • EXPERT
The turn signal switch is shot internally.
Tuesday, September 9th, 2008 AT 4:21 AM
Recommended Guides
