NOT STARTING
STEEM
  • BUICK PARK AVENUE
I have a 1996 Park Avenue with 180,000 miles. It has a 3.8L engine. At first it started to die and sputter when accelerating. We found the fuel pressure to be about 10psi too low and changed the fuel pump. Next it would run fine but failed to start when shut off. When I come back about 30 minutes later it will start and run fine. The code indicated a crankcase sensor which was changed but with no result. It still will not start after running a while but is not indicating any codes. If I let it sit for a while it starts fine again. What should I look for?
Do you
have the same problem?
Wednesday, April 11th, 2007 AT 4:22 PM
MERLIN2021
  • EXPERT
Look on the fuel rail for the pressure regulator.
Tuesday, April 17th, 2007 AT 11:17 AM
Recommended Guides
