Window binding on the way down
DCKELLEY
  • 1998 BUICK PARK AVENUE
  • 3.8L
  • 6 CYL
  • 190,000 MILES
Both my front windows on my car are binding. I started working on the drivers side by lubing it. Now it goes up great but binds in one spot going down. If I help it just a little it goes down fine. I haven't taken the door panel off yet.
I'm thinking it may need to be lubed inside. Just thought i'd check with you all first. Thanks, Don
Thursday, February 21st, 2019 AT 1:41 PM
DCKELLEY
  • 125 POSTS
After lubing it works great!
Friday, February 22nd, 2019 AT 4:23 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Saturday, February 23rd, 2019 AT 12:54 PM
DANIEL DAILEY
  • 12 POSTS
  • 6 CYL
  • FWD
  • 75,000 MILES
Went to put down drivers side window down. Heard a pop and know the window leans forward and cant put window down. I did get it to roll up. What is wrong? Dan Dailey
Saturday, February 23rd, 2019 AT 12:54 PM (Merged)
  • 52,797 POSTS
Window regulator has failed and needs to be replaced.
BUGGZI
Electrical problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 98.450 miles
I have power window's, everytime there is moisture, rain, snow or dew they don't want to open. I can play with the switch to make it go down about 2 inches, then back up a few time, and sometime's it will open. What should I look at to fix this probelm?
WRENCHTECH
  • 20,757 POSTS
The circuit would have to be tested to know for sure but your probably looking at a bad motor. In this car the motor comes with the regulator also.
