Starts then stalls
RAEMARKHANSEN
  • BUICK LESABRE
94 Buick lesabre 3.8 l. With 190000 miles on it. I have a problem with the car. Ait will start then stall after a few seconds.I have replaced the maf sensor sparkplugs had battery tested ok. The spark seems to be ok. Can hear the fuel pump when I turn the key checked for gas comming through the vacuum hose from the regulator. Any other leads or checks I try besides just replacing parts.
New info now have the car running may have had to do with anti theft. Now if you accelerate hard the car will stall.
Thanks Mark
Do you
have the same problem?
Tuesday, April 24th, 2007 AT 9:08 PM
TOMMY42
Replace fuel filter
Sunday, May 20th, 2007 AT 12:32 PM
Recommended Guides
