A/C Heater
RKRIKER
  • BUICK LESABRE
92 Buick LeSabre V-6. My wife's car. When the heater turns on everything works great, but it seems to only come on when it wants to. All the fuses I found are good. The control panel seems to work ok, but the blower doesn't always come on. It's gradually gotten worse. Could it be a switch, a relay, a temp sensor? Where is it located? It doesn't seem to matter if it's in auto or manual on panel. Thanks.
Do you
have the same problem?
Monday, January 22nd, 2007 AT 12:49 PM
CARUNDELL
Hey RK
Access the blower motor, under the right side of the dash. Check the elec. Connector to the blower motor. If that looks ok, then its probably time for a new blower motor. Let us know!
Chris
Monday, January 22nd, 2007 AT 4:01 PM
RKRIKER
[quote="carundell"]
Hey RK
Chris:It was the blower motor, Thanks for the help. :D
Wednesday, January 24th, 2007 AT 2:43 PM
Recommended Guides
