ABS
JWM
  • BUICK LESABRE
1992 LeSabre Limited, climate control, 3.8L Auto4OD, 73,000 miles. R/R rear brake cylinders and master cylinder (dealer). ABS light came on but would reset and be ok (unlike this computer which now won"t place a period on the page>) Was OK for awhile after brake job, then, the light came on this summer and stayed on.
Then, it went off and everything started working jsut as the AC failed. When ABS light was on, there was no self-test. Off, I tried function by putting tire on loose surface---worked fine. ABS and AC---could there be some relationship? Very very weird.
Do you
have the same problem?
Tuesday, August 7th, 2007 AT 12:13 PM
MERLIN2021
  • EXPERT
Only if the wires are in the same harness.
Monday, August 13th, 2007 AT 1:02 PM
Recommended Guides
