1998 Buick Lesabre care wont start
ADAM DAH
  • 1998 BUICK LESABRE
  • 6 CYL
  • 75,000 MILES
I think its in the sycurity system. Have had the problem before. Its my moms an she had to unlock passanger then driver side door to make it start. Is the problem in the steering coulum. And is it hard to fix?
Do you
have the same problem?
Wednesday, January 7th, 2009 AT 12:38 PM
DE772601
Hello I don"t think the problem is in the steering column from what you are saying the problem is in the security system itself. First thing is to see if its a factory alarm or after market and check the remote to see if the battery is dead in it and if not start checking for any ground wires that are not making a good connection that may be causing the alarm to work properly. Hope this will put you on the right track
Wednesday, January 7th, 2009 AT 4:57 PM
Recommended Guides
