1997 Buick Lesabre Fan
MERCURY1234
  • 1997 BUICK LESABRE
Engine Cooling problem
1997 Buick Lesabre 6 cyl Two Wheel Drive Automatic
Is there a fusible link in the wiring that protects
the cooling fan. I have tried fuses an relay switch.
The fan works if wired direct. Could you show me
a wiring diagram. The motor is a 3.8 engine.
The car is a Buick Lesabre Limited.
Thanks !
Do you
have the same problem?
Thursday, May 20th, 2010 AT 7:33 AM
Check and test the coolant temperature sensor
Thursday, May 20th, 2010 AT 8:47 AM
Recommended Guides
