Starter replacement?
ASHLEY LEWIS
  • 1995 BUICK LESABRE
  • 6 CYL
  • FWD
  • 120,000 MILES
Intermittent problem with starter engagement circuit starter tested on bench ok voltage good on wire to solenoid when starter engages do I need to replace it?
Do you
have the same problem?
Sunday, January 6th, 2008 AT 8:32 PM
  • 31,938 POSTS
Check battery earth and pos terminal clean & tight, I would still check or at least clean starter and check solenoid contacts, bench testing is not always fool proof.
This guide will help walk you through the steps
Mark (mhpautos)
Tuesday, October 2nd, 2018 AT 12:48 PM
JEFFERY W
  • 6 CYL
  • 211,000 MILES
My car wont start had the starter and batttery checked all good they tell me its the starter relay the lights inside the car go dim but the head lights dont go dim
Wednesday, November 18th, 2020 AT 8:17 AM (Merged)
HMAC300
  • 48,606 POSTS
First if you have another key try that as the chip may be bad in your key then switch relay with a like relay to see if it's actually the relay or not.
Here is guide to help
and
TEXAS409
  • 10 POSTS
  • 1994 BUICK LESABRE
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 160k miles
Ground Wire on Starter Not stayin Hot after letting go of key after being cranked
BUDDYCRAIGG
  • 2,262 POSTS
There is no ground wire for the starter.
And the small wire (probably purple) is not supposed to have power after you let go of the key
TEXAS409
  • 10 POSTS
Yes it is a purple/white stripe wire, but most likely I think it wont stay runnin because security light on dash is blinking
BUDDYCRAIGG
  • 2,262 POSTS
That would do it.
I don't have any experience with resetting the security on a GM.
You should post a new questions describing what the car is doing and that the security light is flashing.
In the mean time, i'll do some snooping for an answer too.
BUDDYCRAIGG
  • 2,262 POSTS
I've got some more info
General instructions on pass-lock relearn:
So the engine cranks but it wont start? IS the security light flashing? If so try this
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
TEXAS409
  • 10 POSTS
That didnt help me I tried almost everything but now, any one who has VATS problem with there lesabre I highly recommend you to get a VATS BYPASS KIT my car cranked 1st try
BIGIS2007
Electrical problem
1994 Buick Lesabre 6 cyl Wheel Drive Type unknown Automatic 112000 miles
when I turn my key it just does a click noise. My battery is fine. If its the starter where do I find it and how do I change it
BMRFIXIT
  • 19,053 POSTS
Starter is mounted on the engine/tranny mid of car in front
it looks similar to that
it mount on by two bolts
make sure you
Disconnect the battery negative before any work
starter wired straight to the battery
and series damage can be caused to you or the system if wires touch ground or tools that is grounded
https://www.2carpros.com/forum/automotive_pictures/99387_starter_2.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_starter_1_2.jpg
Wednesday, November 18th, 2020 AT 8:18 AM (Merged)
SUGARBABY1964
How do you change a starter yourself at home
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable.
Raise and support vehicle. As required, remove nuts from A/C compressor, exhaust system and/or engine braces, adjacent to starter.
Remove other items that may interfere with removal of starter.
If necessary, remove nut from engine cross brace. Using pry bar between upper engine mount and engine, pry rearward and support engine.
If necessary, remove oil filter, air induction tube and cooling fan.
Disconnect wiring at starter, and note position.
Remove starter mounting bolts and any shims.
Remove starter.
Installation
Before installation, ensure pinion-to-flywheel clearance is.020" (0.5 mm).
Add or subtract shims as necessary.
To complete installation, reverse removal procedure.
Tighten mounting bolts
HFA
  • 6 CYL
  • FWD
  • 130,000 MILES
Please tell me how to remove the rear starter bolt. I removed plastic flywheel shield, there is another plastic shield that goes under the starter that I can't see how to remove.
2CARPRO JACK
  • 11,533 POSTS
Some of those shields have a small 10mm bolt opposite of the starter on the front of the trans. You will have to look up betweent the trans and engine to see it.
HFA
There was a 10mm between the oil pan and transmission which held on the flywheel inspection cover, but that didn't release the cover around the starter. No exploded parts diagrams?
2CARPRO JACK
  • 11,533 POSTS
Not for something like that. There is another one facing forward (radiator)on the trans, above the starter bolt
RIVERMAN55
Where is the starter and what is involved in changing it. Simple or does it in volve a lot of taking things apart to get to the starter
ZACKMAN
  • 4,202 POSTS
If you lie down under the engine, you will see it towards the front of the engine, just a few inches off of the radiator. You will need to remove a flywheel cover (2 bolts) and then you can remove 2 mounting bolts for the starter. Keep in mind that you have two bolts on the starter body that need to come out as well.
WARESINK29
  • 1993 BUICK LESABRE
Electrical problem
1993 Buick Lesabre Two Wheel Drive Automatic
i turn the key on and everything comes on in the car but when I turn it more to start it nothing happens. I have put a new starter on it but that wasn't it
