1982 Buick Lesabre IT WANT CRANK
MZ_FOXYDIVA5
  • 1982 BUICK LESABRE
1982 Buick Lesabre 6 cyl Front Wheel Drive Automatic
MY CAR WANT CRANK IT WANT TURN OVER ITS LEAKING OIL TIME U PUT SOME OIL IN IT SOME DAYS LATER ALL THE OIL IS OUT OF THE CAR AND ITS ALSO 26 YRS OLD WHAT COULD BE THE PROBLEM AND THE MOTOR THATS IN IT DOESNT BE LONG TO THE CAR THE MOTOR THATS IN IT IS A 350 MOTOR FROM A 85 OR 86 BUICK I DONT HAVE A PICTURE OF MY CAR DO U MIND IF I SEND IT IN LATER.
Do you
have the same problem?
Wednesday, February 17th, 2010 AT 6:50 PM
ERNEST CLARK
  • EXPERT
There's several ways the oil can leak out of the engine.
There could be a leak in the oil pan, crankshaft rear manin seal, timing chain cover, valve covers, or even the oil drain plug could be loose.
If your engine is smoking a lot, then it could be leaking into the cylinders of the motor and out of the tail pipe. Though that would use up your oil a lot slower than in a couple days.
Saturday, February 20th, 2010 AT 7:36 AM
Recommended Guides
