2003 Buick Century power steering leak
MRGARYM
  • 2003 BUICK CENTURY
  • 6 CYL
  • FWD
  • 101,000 MILES
It looks like I have a leak in the area where the steering gear connects to the rack & pinion assy. There is a nut on the bottom that I think holds the gear to the rack and that is where the leak seems to be. Is there a seal kit I could get to stop the leak? Or do I need to replace the entire rack&pinion assembly. Thank you
Do you
have the same problem?
Tuesday, May 26th, 2009 AT 3:18 PM
JALOPYPAPA
The rack and pinion is usually replaced as a unit.
Friday, May 29th, 2009 AT 2:32 PM
Recommended Guides
