2002 Buick Century 2002 Buick Century failed to start
RAMK71
  • 2002 BUICK CENTURY
  • 6 CYL
  • 50,000 MILES
Morning drove from home to office good. In the evening failed to start. Headlight, dashboard, wiper, lock, radio etc, works fine as usual (looks battery is strong enough). In start position nothing happens no click sound or cranking. It was sub zero temperature but it started good before with the same temperature.
Please post your valuable suggestion.
Do you
have the same problem?
Thursday, January 1st, 2009 AT 10:29 PM
  • EXPERT
Hi:
A couple things to check. First, is the security light on when you turn the key to start? Also, have a helper turn the key to the start position while you check for voltage to the starter (small wire). You may want to also check the starter relay under the hood. If there is another relay with the same part number in the box, switch them to see if that helps.
Let me know if this helps and what you find.
Saturday, January 3rd, 2009 AT 10:35 PM
Recommended Guides
