2002 Buick Century
SPEREILLO
  • 2002 BUICK CENTURY
  • 6 CYL
  • FWD
  • 90,000 MILES
My cars odometer ans shift indicator do not lighr up any more so you can not tell the mileage on the caror what gear your in. All of the the warning lights and gages are working fine. What could be some of the problems?
Do you
have the same problem?
Thursday, November 19th, 2009 AT 7:47 PM
DANAUTHIER
  • EXPERT
There is a senor in the transaxle that sends speed information to the powertrain control module (pcm) that may be the issue. The pcm is also a possibility or the instrument cluster itself. Is the cluster didgital or does it have needle gages? Is you check engine light on? If it is, have you had the codes read? Fault codes are a very valuabule starting point in any diagnosis.
Just a few ideas, let me know.
Dan
Thursday, November 19th, 2009 AT 11:49 PM
Recommended Guides
