Low tire light
CASSIE198
  • 2001 BUICK CENTURY
16,000 miles
My low tire light came on in my car listed above )Limited model). I put air in all of my tires and the ' low tire' light has not gone off. How do I turn it off?
Do you
have the same problem?
Tuesday, September 29th, 2009 AT 12:13 PM
  • EXPERT
The light will go off by itself it is a real time system you have a tire pressure sensor that is not working by chance you change a tire out lately? This would be the tire I would suspect.
Cheers, Joe
Wednesday, October 7th, 2009 AT 1:33 PM
BEVDIRKIN
  • 2003 BUICK CENTURY
Six cylinder front wheel drive automatic 77,000 miles.
How do I reset the low tire light? I had a flat tire and the light gave me a warning. Now it needs to be reset and I tried the reset button on the fuse panel, but it did not take care of this.
Saturday, June 23rd, 2018 AT 2:31 PM (Merged)
SERVICE WRITER
  • EXPERT
Adjust all tire pressures to the recommended 30 psi.
Turn on the ignition, with the engine off.
Press and hold the red reset button located in the passenger side instrument panel fuse block.
The low tire indicator will flash three times, then turn off.
After resetting, the TPM system requires up to thirty minutes of straight line driving in each of the three speed ranges to complete the calibration process.
BENTON
V6 two wheel drive automatic 40,000 miles.
The inflation pressure is has been corrected on all tires. How do you reset the "low tire light"?
TECH1
Inside the passenger side fuse block, there is a red 'reset' button. With the key in the on position, press and hold the button until the light on the dash goes out. The passenger side fuse block is gained through pulling the cover on the far passenger side of dash in the door opening area.
BOBANDLINDA
  • 2000 BUICK CENTURY
Six cylinder.
All of my tires are properly inflated and the low tire light will not go out. We do not have a manual. How do we turn it off?
CHARLIE4994
I just did this a week ago and as you I do not have a manual. Okay on the passenger side of the driver open the door. Their is a fuse box on the side of the dash. Open that up and their is a red reset button. Now turn on your vehicle and press the reset button until the low tire indicator go off.
That should do it. I have not had a problem since then.
BONNIE RICHARDSON
  • 2002 BUICK CENTURY
Front wheel drive automatic 58,000 miles.
After tires have been properly inflated the "low tire" light staying on.
DOCFIXIT
  • EXPERT
The pressure monitor in that tire maybe faulty.
RLELEN
Six cylinder automatic 33,000 miles.
Low tire light stays on.
DOCFIXIT
  • EXPERT
Faulty sensor in wheel.
AZHOMBRE
Mine stayed on, so I went to discount tires and the service attendant came and pulled the fuse panel off the right side of the dash and held the button in for a few seconds and the light went out. He showed me how to do it, that is why I know! I would check this first before replacing the wheel sensor.
Tire pressure should be the same in all tires before resetting the switch in the fuse panel.
Recommended Guides
