What are the torque specs on the rocker arms
ANONYMOUS
  • 2003 BUICK CENTURY
  • 127,000 MILES
Tuesday, January 22nd, 2013 AT 5:08 AM
GMTECH
  • 537 POSTS
The torque spec is 24 ft lbs
Cheers
Saturday, February 2nd, 2013 AT 5:25 AM
JERRY BRUIN
  • 1998 BUICK CENTURY
  • 6 CYL
  • 100,000 MILES
I have a 1998 3100 Buick engine with 100k. I have just started to experiance noisy rocker arms when starting the engine that lasts from 5 to 10 minutes, but not every time I start the engine. This seems to be intermitante but happening more often. I would like to have an idea what to look for as being the problem. Jerry
Friday, January 10th, 2020 AT 12:21 PM (Merged)
  • 108,179 POSTS
Hi:
Make sure you are using the correct weight oil. Also, make sure the oil filter you use has an anti siphon valve so it can't take extra to get oil pressure.
