Coolant temperature sensor location for replacement?
RICHARD KNAPP
  • 2002 BUICK CENTURY
  • 6 CYL
  • FWD
  • 130 MILES
Where is it and can I get to it myself?
Thursday, February 18th, 2016 AT 3:06 PM
CATAFINA
  • 168 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Friday, February 19th, 2016 AT 1:15 AM
JHELMS1659
  • 1994 BUICK CENTURY
Where is the engine coolant temperature sensor cooling fan won't run when it gets to right operating temp
Wednesday, May 26th, 2021 AT 12:25 PM (Merged)
  • 108,133 POSTS
Hi:
From the front of the car, it's on the right rear of the right rear of the engine. Look at the attached picture. It's item N5 (hard to see) behind the letter M.
I hope this helps:
https://www.2carpros.com/forum/automotive_pictures/249084_Graphic_4.jpg
Positive feedback is appreciated.
URP13
  • 1995 BUICK CENTURY
  • 6 CYL
  • FWD
  • 140,000 MILES
Tools, parts, and instructions needed.
WRENCHTECH
  • 20,757 POSTS
There is nothing special with tools or parts. The stat seals with an O-ring. The hardest thing is just reaching the bolts as they can be difficult. An extension with a 13mm swivel under the exhaust pipe usually works.
TORF
  • 1992 BUICK CENTURY
Where is the coolant temperature sensor located on the engine of the 92 Buick Century. According to the computer we are getting a code 14 and want to change the coolant temperature sensor, but want to know where it is located on the engine?
JNOVACK
  • 723 POSTS
Coolant Temperature Sensor On your 1992 Buick Century 3.3L FI OHV , the Coolant Temperature Sensor is located:
Under hood, passenger side, upper engine area, below alternator, mounted in intake manifold
The CTS its located on right side of engine under the alternator item no. 3
Here is a guide and the coolant sensor location for both 4 and 6 cylinder engines
Check out the diagrams (Below)
Cheers
PHIB
The image uploaded for the 3.3 is correct, but the notation is wrong. The sender is mislabeled as the sensor and vice versa. Thanks
Saturday, August 20th, 2022 AT 6:07 AM
