Where is the turn signal flasher located
JSGK77
  • 1993 BUICK CENTURY
I have searched everywhere under the dash and I am not seeing anything that even looks like the turn signal flasher! Is there somewhere else I should be looking?
Do you
have the same problem?
Thursday, July 17th, 2008 AT 2:06 PM
It is on the accelerator pedal bracket here is a diagrams below to show you. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Thursday, July 17th, 2008 AT 2:22 PM
JENN16051
My hazard lights work but I have no turn signals they do not light up on the dash or on the car. What could be the issue?
Friday, September 7th, 2018 AT 4:19 PM (Merged)
  • EXPERT
Hi:
It could be a couple things. The switch, flasher, or relay could be bad. The cheapest and easiest thing to try would be the flasher.
Let me know if that helps.
SPILLTHEBEANS
Six cylinder front wheel drive automatic.
Checked fuse and is good. Blinker will not work and tail backup and parking lights all on same fuse and work.
ZACKMAN
Check your turn signal flasher.
http://www.2carpros.com/forum/automotive_pictures/55316_93centuryflasher_1.jpg
NAN JOHNSON
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 100,000 MILES
How can I replace the turn signal relay?
Friday, September 7th, 2018 AT 4:20 PM (Merged)
SATURNTECH9
  • EXPERT
The flasher relay is on a bracket above the pedal unplug and unclip it.
Recommended Guides
