1988 Buick Century overheating
POLLAG
  • 1988 BUICK CENTURY
  • 6 CYL
  • FWD
  • 98,850 MILES
Hello guys,
I have replaced the radiator because of visible blockage, the water pump because of leaking, the thermostat for s&g, replaced cap and flushed the system.
I have bypased the fan relay (because the fan does not come on)by jumping power to the big yellow wire.
fan comes on so I replaced the relay.
Later I found the fan still does not turn on, unless the a/c is on.
Just overheated today at a drivethru Temp light came on and fluid boiled over to resevoir, can you advise before I crack the head? Is there more than one relay? Can I get a schematic and sensor location?
Do you
have the same problem?
Thursday, May 6th, 2010 AT 2:13 PM
  • EXPERT
Have you confirmed that the fan motor is good?
Monday, June 7th, 2010 AT 8:45 AM
Recommended Guides
