Replacing front CV axles?
BKEHR
  • 2000 CHEVROLET BLAZER
I was told the front axle boots on my car are busted and need to be replaced. What causes this and what kind of expense is it to repair?
Thursday, October 1st, 2009 AT 11:45 AM
  • 108,169 POSTS
They get old, dry rot, and rip. As far as replacement, most shops just replace the half shaft which includes the axle and both CV joints. This video shows the job being done on a similar car but the process is the same.
https://youtu.be/XeqT-_fwVQg
That is what I would recommend. A half shaft is around 150.00 each and labor is around 3 hours for both.
Monday, October 19th, 2009 AT 10:34 AM
COOLER1981
What is the best way to change out the cv half shaft seal on the driver side front and do I have to open up the front diff to complete the job
Friday, May 14th, 2021 AT 12:15 PM (Merged)
SWILLIAMS
  • 597 POSTS
Do you mean the seal IN the axle housing or one of the CV boots?
If you mean the one in the housing that seals the stub shaft, Remove the drivers side half shaft. Then you can remove and replace the seal. Check the bearing while you have the seal out. It can also be replaced while you're there. Just be careful installing the new one.
Once you have the new seal in it would be a good idea to check/change the front axle lube in case any was lost through the bad seal.
COOLER1981
Ok ya it's just the shaft seal and bearing's that I have to change tha crappy part is there are no bolts holding the half shaft in place so it's get the shaft out that is the problem it's a free floater set up but thx for the info it is going to help
SWILLIAMS
  • 597 POSTS
OK, to pull the half shaft is simple. First you need to jack up the front, pull the tire/wheel off. Now you need to remove the nut in the middle of the hub. Next step is to use a block of wood to break the axle loose from the hub, one good whack on the wood block on the end of the shaft should get it loose. Next you want to position a jack under the lower A arm. You will also want to remove the brake caliper for extra room. Just remove the two caliper pins and hang it out of the way. Now remove the pinch bolt from the lower steering knuckle area. Then GENTLY pry the ball joint free from the knuckle. Now you can pull out on the knuckle and push in on the axle at the same time. Now that you have the axle free on the outer end. Reach in around the inner tri-pot joint with a couple pry bars. You just pop the axle free (there is a small snap ring inside) and it will come out. Change the parts and reverse the procedure to put the axle back in. Torque the pinch bolt to 30 ft. Lbs (good and tight if you don't have a torque wrench) The large axle nut gets torqued to 120 ft. Lbs.
BHORNET40
  • 1998 CHEVROLET BLAZER
When ever I drive it it makes a noise like it is hitting something and I can feel vibration in the floorboard on passenger side but it does it the most when I turn it too the left but still does it when I straighten it back up
OBXAUTOMEDIC
  • 3,711 POSTS
It sounds like it is your CV Axle, However, it could also be the wheel bearings. To check these, jack up the front of the vehicle stabilize with jack stands. Then crawl under and grab the cv axle at near one of the boots, now twist it, does it have a lot of play? If not do same at the other boot on same axle. If has a lot of play replace cv axle. If all feels good and tight then check bearings. To do this just grab the wheel at top and bottom, now pull out at bottom and push in at top, it should have very little to no play. If has a lot of play then replace bearing. Check both driver and passenger sides.
JESS KELLEY
  • 6 CYL
  • 4WD
  • 146,378 MILES
When replacing the front axle and cvc joint was is the standard practice, showed I replace the whole axle or just the part from cvc to cvc.
MIKE H R
  • 3,094 POSTS
Depending how the other cv joint is you should only need to replace one. It is recommended to replace both. Check with a local auto store, most have axles that are rebuilt and can be put on in one piece.
HAGERRS
I am having trouble getting the left cv axle disconnected from diff. I have everything taken off axle just wont come out. I see on the new axle there is a retaining ring?Need help please
JETSA
  • 117 POSTS
You have to "pop" it out, such as with a prybar. Find somewhere to pry against and put your prybar against the metal part of the axle near the transaxle, then pop it out. Sounds scary but that is the procedure.
MLONG98
  • 74 POSTS
  • 1987 CHEVROLET BLAZER
  • 2.8L
  • 6 CYL
  • 4WD
  • 160,000 MILES
Long story short, I did not abuse it and it randomly broke on me, boots been ripped forever too. I was able to pull some metal pieces from inside the front passenger boot. Anyway, I am needing to find out if all I need to replace is the CV axle. It also will me spin it freely by hand, as if it is not connected to the tire. Cannot afford a look over from a mechanic.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That looks like broken pieces of the CV joint cage that holds the steel balls.
Why do you not just go take the complete axle along with the CV joint from a car in a salvage yard?
You can find if there are any 1987 Chevrolet s10 Blazers near you with this nationwide database of salvage yards.
http://www.car-part.com/
MLONG98
  • 74 POSTS
My nearest real salvage yard of any kind is about ninety miles away. If the cage is broken would that mean my axle is fine? And I will just need a CV joint?
MLONG98
  • 74 POSTS
I will not be doing the repairs but I do have to find out what is wrong. I need to keep the amount of things to replace limited.
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You can just purchase the entire CV axle assembly from Summit Racing for about $50.00.
https://www.summitracing.com/search/year/1987/make/chevrolet/model/s10-blazer/part-type/axle-shafts-direct-fit?N=4294950300%2B4294951398%2B4294949276%2B4294945517&SortBy=Default&SortOrder=Ascending&keyword=cv
MLONG98
  • 74 POSTS
Came out to about $70.00 with basic shipping, it would not give me a delivery day. Do you know about how long that is by chance? Is the vehicle still driveable without risk of something worse happening?
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Summit Racing is usually pretty fast, like two to three days.
It's hard to say what may go wrong next, but anytime you notice the boot torn you must replace the boot and grease so the CV joint doesn't wear out from no grease.
MLONG98
  • 74 POSTS
Just got it in, it didnt come with a cage of any kind like what's broke?
MLONG98
  • 74 POSTS
So what else am I gonna need?
