Brakes
JOHNDUVALL
  • 1981 CHEVROLET SILVERADO
  • V8
  • 350,000 MILES
Brake peddle goes all the way to the floorboard even after bleeding.
Do you
have the same problem?
Monday, July 17th, 2017 AT 9:48 AM
CJ MEDEVAC
  • EXPERT
Your master cylinder may be "internally leaking" (the plunger is allowing fluid to pass by). If so, a new one is in order.
Before you jump on that see if this is the way you are bleeding the system.
See my answer in the link below.
https://www.2carpros.com/questions/1999-ford-f-150-brakes--3
Return with your results.
The Medic
Monday, July 17th, 2017 AT 5:34 PM
Recommended Guides
