Brake pedal goes to the floor after replacing rear brake pads
EVANSA
  • 2006 MERCEDES BENZ R350
  • 6 CYL
  • 90,000 MILES
Change rear brake pads and now pedal goes to floor. Tried to bleed rear calipers, but no brake fluid comes through either rear caliper.
Do you
have the same problem?
Tuesday, March 13th, 2018 AT 8:08 AM
  • EXPERT
Try running engine and do a bleed, if nothing get back and I will look further into the system, but in the manual it says just do a static bleed.
Tuesday, March 13th, 2018 AT 4:49 PM
Recommended Guides
