My wife was driving and the brakes started locking up?
GRIZLYMULE
  • 2017 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 108,000 MILES
First off about 2 years ago the truck was hit on the left side just in front of the rear wheel and did clip the rear wheel and the axle was replaced during repairs. (2) I replaced brake pads on the truck a few months ago for the first time and had bought the truck new. I'm not a mechanic but have done brake jobs on every vehicle I've ever owned over 40 years and it's been my experience that the rear brakes, also disc by the way, only need changing about every other time the fronts are changed because most of the braking power is in front but the rear pads were badly worn especially the right rear which was down to metal and even needed a new rotor. I bled the brakes according to specs. Within a day or two, my wife was driving and the brakes started locking up and when she pulled over could smell the brakes and said the right front was smoking. When I looked at it the right front and rear rotors were blackened from getting hot but the left side wasn't maybe slightly. I've spent hours online trying to find the problem and have changed the right front caliper just to try and see if it helped. It did not. I drove it about 20 miles holding up on the brake peddle because my wife says she pumps the peddle from underneath and says it helps and the brakes never locked up so a mechanic friend said replace the booster which I did and that also didn't work so I returned it and put the old one back on. I wonder if the hit to the left rear damaged something like a module. I have visually inspected the lines/cables to all of the wheels and didn't see anything loose or broken. Hoping this doesn't run into $1000's to fix. Warning lights intermittent Check Trailer brake system, Stabilitrac, and Antilock system lights. The Trailer Brake system is the one that lights up the most often dinging a few times then going off sometimes several times then not for a day or two. I have cleaned the connection off on that module because I saw it in a video.
Sunday, January 31st, 2021 AT 11:13 AM
  • 52,797 POSTS
Good afternoon,
I suspect the brake hose is collapsed in the right front not allowing the pads to release.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Pump up the pedal and jack up the right front. I bet it is tight to turn or almost locked up. Open the bleeder and see if fluid shoots out. If it does, then the wheel will turn and that will confirm the hose is the issue.
Sunday, January 31st, 2021 AT 1:35 PM
GRIZLYMULE
  • 9 POSTS
I'll try changing hoses on all four to see if that works because I'm having issues with all of them. Thank you, sir and I'll get back to you.
Wednesday, February 3rd, 2021 AT 7:23 AM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Wednesday, February 3rd, 2021 AT 8:23 AM
HAJOK
  • 7 POSTS
  • 2015 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 45,000 MILES
I have to bring the truck to a stop. I pump the brakes and they release. I have changed the booster, the air pump to the booster and the cruise and brake module. It still does it. Help
Monday, February 22nd, 2021 AT 11:35 AM (Merged)
  • 108,179 POSTS
Since it is only the front brakes, I question the master cylinder. Try this. When the brakes are locked up, see if they release if you open the brake line at the master cylinder. If it doesn't, work forward. Move to the caliper. Open the bleeder and see if the brake releases.
I have seen situations where the rubber brake hose on the calipers would fail internally causing the brake pads to remain partially actuated or fully. When driving, there would be enough drag on the brakes to cause them to get hot. Now, brake fluid expands when it is hot, so the brakes would slowly continue to engage.
If the brakes release when you open the bleeder on the caliper, replace the rubber brake hose.
Let me know what you find.
HAJOK
  • 7 POSTS
I would say it's got to be something in the electronics of the master cylinder is working fine. It's releasing but the traction control light keeps coming on. If you turn it sharp right or left or if the brake locks up. It'll flash on and then flash off, so it's got to be something in the ABS. I just don't know.
  • 108,179 POSTS
Welcome back:
I didn't realize turning caused this problem. With that in mind, the first thing I would check are the ABS sensors on the front wheels. Check to confirm the wiring isn't damaged, shorted, or not properly plugged in at the connector.
I attached pictures of where the wiring mounts and sensor location. Check both sides. Also, based on the year, I strongly recommend scanning the computer for diagnostic trouble codes.
HAJOK
  • 7 POSTS
Turning never caused this problem, it just started when I turn it it acts like it's shaking.
  • 108,179 POSTS
Are you sure the brakes aren't hanging up a bit all the time?
HAJOK
  • 7 POSTS
Yes.
  • 108,179 POSTS
Welcome back:
I forwarded this to the owner for his ideas or suggestions. Expect a response from Ken. I will continue watching what is happening and try to help.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
There are a couple things that come to mind first is the push rod that from the booster needs to be adjusted inward, when the brake are locked loosen the master cylinder mounting bolts if the brakes start rolling you know the push rod is the problem next we should run the codes becasue it sounds like the ABS/traction control module is going out. Lets run the codes to confirm the issue
https://youtu.be/rTtAnsOlZU4
If the module is to blame this video with show you how to replace it with instruction and diagram below to help show you on your truck.
https://youtu.be/lUotkKXG9dY
ABS traction control module replacement reprogramming.
Note:
DO NOT program a control module unless directed to by a service procedure or a service bulletin. If the control module is not properly configured with the correct calibration software, the control module will not control all of the vehicle features properly.
Ensure the programming tool is equipped with the latest software and is securely connected to the data link connector. If there is an interruption during programming, programming failure or control module damage may occur.
Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. When required install the EL-49642 - SPS Programming Support Tool to maintain system voltage. If not available, connect a fully charged 12?V jumper or booster pack disconnected from the AC voltage supply. DO NOT connect a battery charger.
Turn OFF or disable systems that may put a load on the vehicles battery such as; interior lights, exterior lights (including daytime running lights), HVAC, radio, etc.
During the programming procedure, follow the SPS prompts for the correct ignition switch position.
Clear DTCs after programming is complete. Clearing powertrain DTCs will set the Inspection-Maintenance (I-M) system status indicators to NO.
Reference Information
Special Tools
Replace and Program Control Module or Reprogram Control Module
To program a replacement or an existing control module, perform the following procedure:
Install EL-49642 - SPS Programming Support Tool .
Access the Service Programming System (SPS) and follow the on-screen instructions.
On the SPS Supported Controllers screen, select K17?Electronic Brake Control Module - Programming and follow the on-screen instructions.
On the SPS Supported Controllers screen, select K17?Electronic Brake Control Module - Configuration and Setup while following the on-screen instructions.
At the end of programming, choose the “Clear All DTCs” function on the SPS screen.
Unsuccessful Programming Recovery
In the event of an interrupted or unsuccessful programming event, perform the following steps:
Ignition ON. Ensure the control module, DLC and programming tool connections are secure and the SPS software is up to date.
Verify the control module can be reprogrammed.
If the control module cannot be reprogrammed
Ignition OFF for one minute, ignition ON.
If the control module cannot be reprogrammed, replace the control module.
If the control module can be reprogrammed.
All OK.
All OK.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair.
Control Module References for Control Module replacement, programming and setup
Like JACOBANDNICKOLAS said it could be a bearing hub going out causing the wheel speed sensor to have a false reading.
https://youtu.be/ZgiPRG6jffc
HAJOK
  • 7 POSTS
Found the problem and it was not showing up on the scanner. We've changed the brake booster the air component that went to the booster the brake lines the master cylinder. Could not find anything wrong it was not showing on the scanner the codes weren't there we were changing these parts one at a time and it was still doing the same issues. The first thing we changed was the booster then it showed up it wasn't getting enough air to the booster so we change that component then we change the brake lines then we changed the master cylinder. We were perplexed and could not find the issue we had two other mechanics looking at it. One of them and told us that sometimes the boosters can be bad even though it was from GM and come right out of the box we went back to that we changed and put a new booster on that was the problem. Thank you for everyone helping with this. We just found the problem yesterday we've been two weeks working on this.
  • 108,179 POSTS
Happy to help. What was the actual problem? I'm sure it will help someone in the future.
HAJOK
  • 7 POSTS
We change the brake booster, the pump, the brake lines, and the master cylinder. The new brake booster we put in from GM was bad.
  • 108,179 POSTS
Wow! You buy the best and this happens. However, I guess it can happen.
Regardless, I'm glad it's fixed. Take care and let us know if you have questions in the future.
HAJOK
  • 7 POSTS
Thank you and everyone else.
MIKALYNN BURKE
  • 2014 CHEVROLET SILVERADO
  • 4.3L
  • V8
  • 4WD
  • 67,000 MILES
I was driving down the road was coming up to a stop sign and my truck did not want to stop, so for me to stop I had to press hard on the brakes. Now it seems my brakes are sort of locked up. My brake pedal is stiff and hard and I have to press hard on the pedal to stop the truck and when I do it makes like a grinding sounds. I have took out my ABS fuse to see it that was the problem, nope still doing it I have no idea what is going on with it. It acts like it is slowing it self down. Please someone help me.
HMAC300
  • 48,601 POSTS
It sounds like there may be an ABS problem where it is done this and even removing fuse will not cure it. this will have to be scanned for codes. Check out this video
it cold be hydraulic as well but I kind of doubt it from your description.
  • 108,179 POSTS
Happy to help. And I can't believe I missed your identifying the problem in your prior post. Sorry about that.
