Brakes
TAMMY BLAND-PRUITT
  • 2003 CHEVROLET SILVERADO
  • 181,234 MILES
New rotors and brake pads on back. Tires smoking. Why are they hot?
Do you
have the same problem?
Sunday, June 19th, 2016 AT 7:03 AM
JDL
  • EXPERT
Your parking brake is released, correct? Is it smoking on both sides or just one? Any abs codes? I would safely raise and support the rear of the vehicle, block the front wheels so the vehicle cannot move. Safety is your responsibility. Put the transmission in neutral, see if you can rotate rear tires, if you cannot have to pull the tire, see if brake is holding it?
Others may have some suggestions?
Sunday, June 19th, 2016 AT 10:39 AM
Recommended Guides
