Brakes
DAVID HACKER
  • 2003 TOYOTA CAMRY
  • 2.4L
  • 4 CYL
  • 250,504 MILES
Going to floor. Brakes they hold fine, but go to floor.
Do you
have the same problem?
Monday, September 12th, 2016 AT 5:33 PM
CJ MEDEVAC
  • EXPERT
Have you had any sort of issues/ repairs/ fiddling with the brake system?
Have you recently replaced pads/ shoes?
*Important* Has the brake fluid reservoir run dry/ out (before being refilled)?
Have you checked the fluid level?
Have you looked for leaks on the brake lines or hoses and fluid streaks on the insides of your tires?
Your turn,
The Medic
Monday, September 12th, 2016 AT 7:41 PM
Recommended Guides
