Brake lights (2 outer parts)are flashing
BENANI
  • 2007 FORD MUSTANG
clicking noise in instrument panel, no brake lights working except third brake light.
Car has been resprayed on the outside. Since reconnecting the battery the brake lights started to go on and off even with the ignition off.
Inside the car you hear and clicking noise, this comes from the instrument panel, when disconnecting it the clicking sound stops. However the brake light keep going on and off.
If I disconnect an reconnect the rear light units they stop flashing, but when you put on the ignition it's back to the way it was before. There is no added alarm system on the car.
The brake lights don't work except the one in the tailgate.
Any help would be appreciated!
Do you
have the same problem?
Monday, September 16th, 2013 AT 5:10 AM
KHLOW2008
  • EXPERT
Check for bad ground circuit at the taillights.
Sunday, September 22nd, 2013 AT 7:44 AM
Recommended Guides
